Fallout 3
Publisher: Bethesda
Fallout 3 is the revival of Interplay’s excellent
Fallout series of games following many years out of the limelight. It’s developed and published by Bethesda and, judging by the success of the game, we’ll be seeing more
Fallout games in the future.
Despite using the
Oblivion engine which is now a few years old, the game looks absolutely stunning. Bethesda has spiced up the graphics a bit since
Oblivion and has extended the engine – there are some great explosions, soft shadows and smoke effects that are particularly noteworthy.
We tested the game by manually playing a section of the game that incorporates a number of explosions and effects that you’re likely to experience during your time in post-apocalyptic Washington DC. We recorded the frame rate using FRAPS.
The in-game details were set to their highest values and both anti-aliasing and anisotropic filtering were controlled by the application settings instead of through the driver control panel. This meant that transparency anti-aliasing was enabled, along with HDR and all of the cool smoke effects.
Fallout 3’s engine is by default capped to 60 frames per second, which can make benchmark results very unclear, especially when testing at lower resolutions or with high end graphics cards. To remove the 60FPS cap you’ll need to find the Fallout3.ini file in \Documents\My Games\Fallout3 and edit the file so that iPresentInterval=0. This removes the frame rate cap, and allows us to get a much better idea of a card’s true abilities.
Even then, recent cards and driver optimisations have started to push Fallout 3's engine to the limit, and the majority of cards on test will be limited by our test system's 3.2GHz quad core CPU at lower resolutions.
All graphs are ranked by
minimum rather than average frame rates, as we feel that this is a more important metric when deciding if a card delivers smooth, playable performance.
Sapphire Radeon HD 5870 1GB Vapour-X
ATI Radeon HD 5850 1GB
ATI Radeon HD 5870 1GB
Nvidia GeForce GTX 295 1,792MB
ATI Radeon HD 5970 2GB
ATI Radeon HD 4870 X2 2GB
Nvidia GeForce GTX 285 1GB
ATI Radeon HD 5770 1GB
20
30
40
50
60
70
80
90
Frames Per Second
20
30
40
50
60
70
80
90
Frames Per Second
20
30
40
50
60
70
80
90
Frames Per Second
20
30
40
50
60
70
80
90
Frames Per Second
20
30
40
50
60
70
80
90
Frames Per Second
20
30
40
50
60
70
80
90
Frames Per Second
For analysis of these results, please read the
Results Analysis page.
